Show flags assigned to a record
For each flagged record, Oracle DMW shows a colored arrow in the first column of the listings (with a flag icon header) to represent the flag with the highest priority for the record. For example, you may see any of the following arrows if the record includes a flag:
  • Shows red up arrow icon = High priority flag
  • Shows yellow right arrow icon = Medium priority flag
  • Shows down green arrow icon = Low priority flag
To see the flags applied to a record:
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings listings in the left panel. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. Select the row with the flag by clicking the arrow icon at the beginning of the row (first column).
    Tip:
    To select multiple records with flags, press the Shift or Ctrl key while you select records.
  6. Right-click and select Show Flags. The Show Flags dialog box opens. You can expand the flags to see details on the state or change it.
  7. Click OK.
