View data lineage
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Listings from the drop-down menu.
  3. Expand Default Listings, Custom Listings, or VC Listings in the left panel. Then, expand a clinical data model from the list.
  4. Select a listing to open it.
  5. Click anywhere in the row of the record.
  6. Right-click and select one of the following to open a graphical representation of the source, target, or preferred path:
    • Show Preferred Path If there are multiple source data items, one must be designated as preferred when the discrepancy is created by a validation check or a person. The system applies the discrepancy to the data items in the preferred path.
    • View Source Data to see upstream data that contributed to the selected data item.
    • View Target Data to see downstream data that the selected data item contributes to. Target data is not available in the Validation Check Listings page.
    Click the tabs at the top of the graphic to display the source, target, or preferred path.
