8 Advanced topics
This section includes details on requirements and how to perform advanced tasks (for example, assign user groups to objects). See the following topics for more information.
- Naming restrictions
- Checkout and checkin
- Clinical One and DMW lifecycle mapping
- Validation status and lifecycle stages
- Assign user groups to objects
- Snapshot labels
- Use the Object Navigator in DMW
The framework of Oracle DMW consists of nested containers - Domains, Application Areas, and Work Areas - where you can define metadata objects (e.g. Business Areas or Programs). While the configuration of this structure is conducted in Oracle LSH, you can browse objects and their definition properties using the Object Navigator in Oracle DMW. - Automatic triggering of transformations and validation checks
- Required syntax for metadata files
- Use SDTM identifiers to support important functionality
- How subject and visit filters work
- SDTM column equivalents in InForm
- How the system tracks data lineage
- Data blinding and authorization
- Data processing types and modes
- Installation
- InForm metadata change detection and synchronization
- Clinical One metadata change detection and synchronization
- Understanding internal objects and error messages about them
