Use the Object Navigator in DMW
The framework of Oracle DMW consists of nested containers - Domains, Application Areas, and Work Areas - where you can define metadata objects (e.g. Business Areas or Programs). While the configuration of this structure is conducted in Oracle LSH, you can browse objects and their definition properties using the Object Navigator in Oracle DMW.
To view more information about how different containers and objects
interact within the application, refer to What is the Organizational Structure? and other adjacent
topics in the Oracle® Life Sciences Data Hub Implementation
Guide.
Parent topic: Advanced topics
