Assign a Planned Output
Use this API to assign a Planned Output to a Report Set Entry (RSE). If the Planned Output is already assigned to a different RSE, you must identify that RSE. This API then unassigns the Planned Output from the original RSE and reassigns it to the RSE you specify.
Name
CDR_PUB_DF_PROGRAM.AssignPIandPOtoRSEntry
Signature
PROCEDURE ASSIGNPIANDPOTORSENTRY( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_RSECOMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_RSEOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_RSEOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_PIOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_POCOMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_POOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_ASGRSEOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_ASGRSEOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_RSECOMPANYID (Mandatory) Enter the Company ID of the Report Set Entry to which you want to assign the Planned Output. To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.Current_Company_ID.
- PI_RSEOBJID (Mandatory) Enter the object ID of the Report Set Entry to which you want to assign the Planned Output.
- PI_RSEOBJVER (Mandatory) Enter the object version of the Report Set Entry to which you want to assign the Planned Output.
- PI_PIOBJID (Mandatory) Enter the object ID of the Program instance to which the Planned Output belongs.
- PI_POCOMPANYID (Mandatory) Enter the Company ID of the Planned Output.
- PI_POOBJID (Mandatory) Enter the object ID of the Planned Output.
- PI_ASGRSEOBJID (Optional) If the Planned Output is already assigned to another RSE, enter the object ID of the other Report Set Entry.
- PI_ASGRSEOBJVER (Optional) If the Planned Output is already assigned to another RSE, enter the object version of the other Report Set Entry.
Parent topic: Create and Modify Programs
