Modify a Manual Validation Flag Value
Use this API to change the value of the Program's manual validation (Force Validation Status to Development) flag.
Name
CDR_PUB_DF_PROGRAM. ModifyProgramDetails
Signature
PROCEDURE MODIFYPROGRAMDETAILS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_PROGRAMOBJTYPE IN OUT CDR_PROGRAM_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_CDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Program definition whose flag
value you want to change.
The following attributes are required: OBJ_ID, OBJ_VER, COMPANY_ID, NS_OBJ_ID, NS_OBJ_VER.
- PI_PROGRAMOBJTYPE (Mandatory) This is a parameter of table type
CDR_PROGRAM_OBJ_TYPE that contains Program definition attributes.
The required attributes are OBJ_ID, OBJ_VER, COMPANY_ID. Enter values to identify the Program definition whose flag value you want to change and enter the new flag value in the attribute MANUAL_VALIDATION_FLAG_RC. Enter $yesno$yes for yes, and $yesno$no for no.
Parent topic: Create and Modify Programs
