Check Out a Codelist
Use this API to check out a codelist. Changed status can be verified through public view 'DME_PUB_CODELIST_V'.
Name
DME_PUB_CODE_LISTS.CheckoutCodeList
Signature
PROCEDURE CHECKOUTCODELIST ( P_API_VERSION IN NUMBER , P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, P_NAMING IN OUT NOCOPY cdr_naming_version_obj_type, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2) );
Parameters
This API has standard parameters (see Standard Parameters) as well as the following parameter:
P_NAMING (Mandatory). This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the codelist you are checking out.
Parent topic: Create and Modify Codelists
