Check In a Codelist
Use this API to check in a codelist. Changed status can be verified through public view 'DME_PUB_CODELIST_V'.
Name
DME_PUB_CODE_LISTS.CheckinCodeList
Signature
PROCEDURE CHECKINCODELIST (P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, p_commit IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, p_validation_level IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, p_naming IN OUT NOCOPY cdr_naming_version_obj_type, x_return_status OUT NOCOPY VARCHAR2, x_msg_count OUT NOCOPY NUMBER, x_msg_data OUT NOCOPY VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) as well as the following parameter:
P_NAMING (Mandatory). This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the codelist you are checking in.
Parent topic: Create and Modify Codelists
