Check In a Load Set Definition
Use this API to check in a Load Set definition.
Name
CDR_PUB_DF_LOADSET.CheckInLoadSetDefinition
Signature
PROCEDURE CHECKINLOADSETDEFINITION( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_BASEOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Load Set definition that you want to check
in.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
- PI_COMMENT (Optional) Enter the reason for checking in the Load Set.
Parent topic: Define and Modify Load Sets
