Undo Check Out for a Load Set Definition
Use this API to undo a check out for a Load Set Definition.
Name
CDR_PUB_DF_LOADSET.UndoCheckOutLoadSet
Signature
PROCEDURE UNDOCHECKOUTLOADSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, x_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PIO_BASEOBJECT IN OUT NOCOPY CDR_BASE_OBJ_TYPE, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- P_COMMIT (Optional) Accept the default value (FND_API.G_FALSE) to ensure that this individual API does not commit upon completion. Enter FND_API.G_TRUE to override the default behavior.
- P_VALIDATION_LEVEL (Optional) Accept the default value to perform full validation. No other values are currently supported.
- PIO_BASEOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE that contains object attributes. Enter values to identify the Load Set
definition that you want to undo check out.
The required attributes are: COMPANY_ID, OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER.
Parent topic: Define and Modify Load Sets
