Check Out a Load Set
Use this API to check out a Load Set definition or definition and instance.
Name
CDR_PUB_DF_LOADSET.CheckOutLoadSet
Signature
PROCEDURE CHECKOUTLOADSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_BASEOBJECT IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2, PI_ISINSTONLY IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_BASEOBJECT (Mandatory) This is a parameter of table type
CDR_BASE_OBJ_TYPE. You can enter values to identify either the Load Set definition or an
instance of it:
- Pass the Load Set definition details if you want to check out and subsequently modify only the definition.
- Pass the details of an instance of the Load Set definition if you want the instance to point to the new version of the Load Set definition.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER,OBJECT_VERSION_NUMBER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER.
To get the OBJECT_VERSION_NUMBER, enter the following query: select Max(OBJECT_VERSION_NUMBER) from cdr_vl_val_docs_v where OBJ_ID = <objid> and OBJ_VER = <objver> and DOC_STATUS_RC ='$VALINFOSTATUS$ACTIVE';
NAMESPACE_OBJ_ID. If you are entering information about the Load Set definition, enter the object ID of its containing Application Area. If you are entering information about the Load Set instance, enter the object ID of its containing Work Area.
NAMESPACE_OBJ_VER. If you are entering information about the Load Set, definition, enter the object version number of its containing Application Area. If you are entering information about the Load Set instance, enter the object version number of its containing Work Area.
- PI_COMMENT (Optional) Enter the reason you are checking out the Load Set.
- PI_ISINSTONLY Enter $YESNO$NO if you are checking out only the definition. Enter $YESNO$YES if you are checking out the definition through its instance.
Parent topic: Define and Modify Load Sets
