Create a Load Set
Use this API to create a Load Set definition, Load Set instance or both.
Name
CDR_PUB_DF_LOADSET.CreateLoadSet
Signature
PROCEDURE CREATELOADSET( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CDRLOADSETOBJTYPE IN CDR_LOAD_SET_OBJ_TYPE, PI_CREATEOBJECT IN VARCHAR2, PI_INSTANCE_SUBTYPE_ID IN CDR_NAMINGS.OBJECT_SUBTYPE_ID%TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL, PI_INSTCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING :(Mandatory) This is a parameter of table type
CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
If you are creating a new definition only or a new definition and an instance of it, enter values for the new definition. If you are creating an instance of an existing definition, enter values to identify the existing definition.
For OBJECT_TYPE_RC enter $OBJTYPES$LOADSET if you are creating a definition only; $OBJTYPES$LOADSETREF if you are creating an instance of an existing definition; and NULL if you are creating a new definition and an instance of it.
- PI_CDRLOADSETOBJTYPE (Mandatory) This is a parameter of table type
CDR_LOAD_SET_OBJ_TYPE that contains object attributes specific to Load Sets. Enter values
for the Load Set that you want to create.
The following attributes are required: COMPANY_ID, ADAPTER_COMPANY_ID, ADAPTER_OBJ_ID, ADAPTER_OBJ_VER.
- PI_CREATEOBJECT (Mandatory) Enter DEFN to create a definition only; INST to create an instance of an existing definition; or BOTH to create a definition and an instance of it
- PI_INSTANCE_SUBTYPE_ID (Optional) If you are creating a new instance, enter
the subtype ID that you want to give the instance.
If you are creating a definition only, do not enter a value for this parameter.
- PI_DEFCLASSIFICATIONCOLL (Optional) By default, the new definition is
classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID.
If you want the definition to inherit its classifications for a particular level from its parent, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Load Sets. Do not enter any values for them.
If you are not creating a new definition, do not enter values here.
- PI_INSTCLASSIFICATIONCOLL PI_INSTANCE_SUBTYPE_ID. If you want to override
If you want the instance to inherit its classifications for a particular level from its parent Work Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
If you are not creating a new instance, do not enter values here.
Parent topic: Define and Modify Load Sets
