Check Out a Notification Definition
Use this API to check out a Notification definition.
Name
CDR_PUB_DF_NOTIFICATIONS.CheckOutNotif
Signature
PROCEDURE CHECKOUTNOTIF( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNOTIF IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2, PI_ISINSTONLY IN VARCHAR2, PI_OPTYPE IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_CDRNOTIF [Mandatory] This is a parameter of table type
CDR_BASE_OBJ_TYPE. Identify the Notification definition you want to check out.
Provide the basic naming attributes: COMPANY_ID, OBJECT_ID, OBJECT_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER. Initialize these attributes in CDR_BASE_OBJ_TYPE.
- PI_COMMENT (Optional) Enter the reason you are checking in the Notification.
- PI_ISINSTONLY Enter $YESNO$NO.
- PI_OPTYPE Enter NULL for this parameter.
Parent topic: Create and Modify Notifications
