Create and Modify Notifications
- Create a Notification
- Create a Notification Recipient
- Create a Notification Link
- Check Out a Notification Definition
- Modify a Notification Definition
- Modify a Notification Instance
- Send a Notification
- Check In a Notification Definition
- Remove a Notification Link
- Remove a Notification Recipient
Parent topic: Workflow Notifications
