Check Out Transformation Maps
Use this API to check out the given transformation map.
Name
DME_PUB_XFORM_MAP.CheckoutTransformationMap
Signature
PROCEDURE CHECKOUTTRANSFORMATIONMAP (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PIO_NAMING IN OUT NOCOPY CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_NAMING (Mandatory). This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the transformation map.
The attributes for this API are:
- COMPANY_ID
- OBJ_ID
- OBJ_VER
- NAMESPACE_OBJ_ID
- NAMESPACE_OBJ_VER
- OBJECT_VERSION_NUMBER
Parent topic: Create and Modify Transformation Maps
