Create and Modify Transformation Maps
This section contains the following public APIs:
- Create Transformation Maps
- Modify Transformation Maps
- Mark Table Maps Not Used
- Mark Column Maps Not Used
- Check In Transformation Maps
- Check Out Transformation Maps
- Undo Checkout Transformation Map
- Auto Map Tables
- Accept Table Mappings
- Auto Map Columns
- Get MappedTo Target Columns
- Accept Column Mappings
- Upgrade Transformation Map
- Install Transformation Map
- Remove Transformation Map
- Validate Transformation Maps
- Update Validation Status
- Execute Transformation Map
- Validate Expression
- Refresh Static Packages
Parent topic: Transformations
