Mark Column Maps Not Used
Use this API to mark column mappings as Not Used.
Name
DME_PUB_XFORM_MAP.MarkColumnMapNotUsed
Signature
PROCEDURE MARKCOLUMNMAPNOTUSED (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PI_MAPOBJID IN CDR_NAMING_VERSIONS.OBJ_ID%TYPE, PI_MAPOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_MAPOBJID (Mandatory). Enter object Id of Column Transformation Map.
- PI_MAPOBJVER (Mandatory). Enter object Version of Column Transformation Map.
Parent topic: Create and Modify Transformation Maps
