Check In a Workflow Definition
Use this API to check in a Workflow definition object.
Name
CDR_PUB_DF_WORKFLOW.CheckInWorkFlowDef
Signature
PROCEDURE CHECKINWORKFLOWDEF( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRWORKFLOW IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_CDRWORKFLOW This parameter refers to the workflow definition to be
checked in.
Initialize in cdr_base_obj_type, the basic naming details (COMPANY_ID,OBJ_ID,OBJ_VER,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER) of the workflow to be checked in.
- PI_COMMENT Comment to be associated with the check in operation
Parent topic: Create and Modify Workflows
