Create and Modify Workflows
- Create a Workflow
- Check Out a Workflow Definition
- Create a Workflow Transition
- Create a Workflow Structure Instance
- Modify a Workflow
- Modify a Workflow
- Check In a Workflow Definition
- Remove a Transition
- Remove a Workflow Activity
- Remove a Workflow Instance
- Remove a Workflow Definition
Parent topic: Workflows
