Check Out a Workflow Definition
Use this API to check out a Workflow definition.
Name
CDR_PUB_DF_WORKFLOW.CheckOutWorkFlow
Signature
PROCEDURE CHECKOUTWORKFLOW( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRWORKFLOW IN OUT CDR_BASE_OBJ_TYPE, PI_COMMENT IN VARCHAR2, PI_ISINSTONLY IN VARCHAR2, PI_OPTYPE IN VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_CDRWORKFLOW [Mandatory] This is a parameter of table type
CDR_BASE_OBJ_TYPE. Enter values to identify the Workflow definition that you want to check
in.
The following attributes are mandatory: COMPANY_ID, OBJECT_ID, OBJECT_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER, OBJECT_VERSION_NUMBER. Initialize these attributes in CDR_BASE_OBJ_TYPE.
- PI_COMMENT [Optional] Enter the reason for checking out the Workflow definition.
- PI_ISINSTONLY (Mandatory) Enter $YESNO$NO. (The $YESNO$YES setting is used internally only.)
- PI_OPTYPE (Mandatory) Enter NULL for this parameter.
Parent topic: Create and Modify Workflows
