Create a Workflow
Use this API to create a Workflow definition or instance.
Name
CDR_PUB_DF_WORKFLOW.CreateWorkFlow
Signature
PROCEDURE CREATEWORKFLOW( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PI_CREATEOBJECT IN VARCHAR2, PI_INSTANCE_SUBTYPE_ID IN CDR_NAMINGS.OBJECT_SUBTYPE_ID%TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL, PI_INSTCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
For OBJECT_TYPE_RC enter $OBJTYPES$WORKFLOW if you are creating a definition only; $OBJTYPES$WORKFLOWREF if you are creating an instance of an existing definition; and also if you are creating a new definition and an instance of it.
- PI_CREATEOBJECT (Mandatory) Enter DEFN to create a definition only; INST to
create an instance of an existing definition; or BOTH to create a new definition and an
instance of it.
Valid parameters are: Definition—DEFN, instance—INST, both —BOTH.
- PI_INSTANCE_SUBTYPE_ID (Optional) If you are creating a new instance, enter
the ID for the subtype you want to give the instance.
If you are creating a definition only, do not enter a value for this parameter.
- PI_DEFCLASSIFICATIONCOLL (Optional) By default the new definition is
classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID.
If you want the definition to inherit its classifications for a particular level from its parent, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero). If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Workflow definitions. Do not enter any values for them.
- PI_INSTCLASSIFICATIONCOLL (Optional) By default the new instance is
classified according to the subtype you assigned it in the PI_INSTANCE_SUBTYPE_ID.
If you want the instance to inherit its classifications for a particular level from its parent Work Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero).
If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Workflows. Do not enter any values for them. If you are not creating a new instance, do not enter values here.
Parent topic: Create and Modify Workflows
