Create a Workflow Structure Instance
Use this API to create a Workflow Structure. These are the Workflow structures: And, Or, Start, End_Success, End_Warning, End_Error, and Fork.
Name
CDR_PUB_DF_WORKFLOW.CreateWfStructref
Signature
PROCEDURE CREATEWFSTRUCTREF( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
For OBJECT_TYPE_RC enter $OBJTYPES$WORKFLOW if you are creating a definition only; $OBJTYPES$WORKFLOWREF if you are creating an instance of an existing definition; and also if you are creating a new definition and an instance of it.
Parent topic: Create and Modify Workflows
