Modify a Workflow
Name
CDR_PUB_DF_WORKFLOW.ModifyWorkFlow
Signature
PROCEDURE MODIFYWORKFLOW( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSIONS_OBJ_TYPE that contains CDR Naming Version attributes.
For OBJECT_TYPE_RC enter $OBJTYPES$WORKFLOW if you are creating a definition only; $OBJTYPES$WORKFLOWREF if you are creating an instance of an existing definition; and also if you are creating a new definition and an instance of it.
Parent topic: Create and Modify Workflows
