Copy Objects into a Work Area
Use this API to copy one or more objects into a Work Area.
Name
CDR_PUB_DF_WORKAREA.CopyObjectsIntoWA
Signature
PROCEDURE COPYOBJECTSINTOWA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_CDRPRREFOBJCOLL IN CDR_PRREF_OBJ_COLL, PI_CDRTARGETCONTAINEROBJECT IN OUT CDR_PRREF_OBJ_TYPE, PI_CHECKINFLAG IN VARCHAR, PI_COPYPRGASSGNMT IN VARCHAR );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_CDRPRREFOBJCOLL (Mandatory) This is a collection of Prref objects that
contains information about the instance objects you want to copy into the Work Area.
Provide values for the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER for each instance object. The PRREF_ID and PRREF_VER attributes store the hierarchy information for objects.
- PI_CDRTARGETCONTAINEROBJECT (Mandatory) This is a parameter of Prref object
type that describes the target Work Area.
Enter values for the attributes COMPANY_ID, OBJ_ID, OBJ_VER, PRREF_ID, PRREF_VER, NAMESPACE_OBJ_ID, NAMESPACE_OBJ_VER,OBJECT_VERSION_NUMBER.
- PI_CHECKINFLAG (Mandatory) Enter 'Y' for this flag.
- PI_COPYPRGASSGNMT (Optional) This parameter is not applicable.
Parent topic: Define and Modify Work Areas
