Define and Modify Work Areas
- Create a Work Area
- Install a Work Area
- Check In a Work Area
- Modify a Work Area
- Clone a Work Area
- Copy Objects into a Work Area
- Clone an Object
- Remove a Work Area
- Get the Usage Intent RC of a Work Area
- Update a Work Area's Usage Intent
- Install a Program
- Apply or Move a Snapshot Label
- Remove a Snapshot Label from a Work Area
Parent topic: Work Areas
