Remove a Snapshot Label from a Work Area
Use this API to remove a snapshot label from the passing Work Area.
Name
CDR_PUB_EXE_SNAPSHOT.RemoveLabel
Signature
PROCEDURE REMOVELABEL( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_WA_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_WA_OBJ_ID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_WA_OBJ_VER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_WA_TABLES_COLL in OUT NOCOPY CDR_WA_TABLES_COLL, PI_LABEL IN CDR_TAB_REF_LABELS.LABEL%TYPE, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
- PI_WA_COMPANY_ID (Mandatory) Enter the Company ID.
- PI_WA_OBJ_ID (Mandatory) Enter the Work Area object ID.
- PI_WA_OBJ_VER (Mandatory) Enter the latest object version.
- PI_WA_TABLES_COLL (Optional) User can pass the collection of table instance of the same Work Area on which user want remove the Snapshot Label.
- PI_LABEL (Mandatory) Label value.
Parent topic: Define and Modify Work Areas
