Apply or Move a Snapshot Label
Use this API to apply a snapshot label to some or all tables and/or views in a Work Area.
Name
CDR_PUB_EXE_SNAPSHOT.SetOrMoveLabel
Signature
PROCEDURE SETORMOVELABEL( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_WA_COMPANY_ID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_WA_OBJ_ID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_WA_OBJ_VER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_LABEL IN CDR_TAB_REF_LABELS.LABEL%TYPE, PI_FORCE_FLAG IN CDR_SUBMISSIONS.FORCE_EXECUTION_FLAG_RC%TYPE, PI_BLIND_FLAG IN CDR_TABLE_REF_JOBS.BLIND_BREAK_FLAG_RC%TYPE, PI_DATE IN DATE DEFAULT NULL, PI_SRC_TAB_COLL CDR_SRC_TABLE_COLL DEFAULT NULL, PI_WA_TABLES_COLL IN OUT NOCOPY CDR_WA_TABLES_COLL, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters. See Functional Rules below for more information.
- PI_WA_COMPANY_ID (Mandatory) Enter the Company ID.
- PI_WA_OBJ_ID (Mandatory) Enter the Work Area object ID.
- PI_WA_OBJ_VER (Mandatory) Enter the latest object version.
- PI_LABEL (Mandatory) Label text.
- PI_FORCEFLAG (Mandatory)
- If set to $YESNO$YES, the API overwrites the previous snapshot label.
- If set to $YESNO$NO the label is not applied.
- PI_BLIND_FLAG (Mandatory) The Blind Break flag ($YESNO$YES, $YESNO$NO).
- PI_DATE (Optional) If this value is used, the API labels only those tables with latest data loads less than or equal to entered value.
- PI_SCR_TAB_COL (Optional) Naming details of source table(s) of view in given
Work Area and corresponding view naming details (to match value with
CDR_WA_TABLES_COLL).
This parameter is of type CDR_SRC_TABLE_OBJ_TYPE and contains the following naming attributes:
- SRC_TI_COMPANY_ID NUMBER(6) Enter the Table or view Company ID.
- SRC_TI_OBJ_ID NUMBER(22) Enter the Table or view object ID.
- SRC_TI_OBJ_VER NUMBER(7) Enter the Table or view object version.
- SRC_TI_LABEL VARCHAR2(4000) Source table's already applied label to any given load.
- VW_TI_COMPANY_ID NUMBER(6) Enter the view Company ID.
- VW_TI_OBJ_ID NUMBER(22) Enter the view object ID.
- VW_TI_OBJ_VER NUMBER(7) Enter the view object version.
- PI_WA_TABLES_COLL (Optional) This is a parameter of type CDR_WA_TABLES_TYPE
that contains table naming attributes.
Use this parameter if the API call is intended to set the label for only a subset of table(s) of an Work Area. It contains following naming attributes:
- TI_COMPANY_ID NUMBER(6) Table COMPANY_ID to which label need to be set.
- TI_OBJ_ID NUMBER(22) Enter the object ID for the Table for which the label needs to be set.
- TI_OBJ_VER NUMBER(7) Enter the object version for the Table for which the label needs to be set.
- TI_RET_STATUS VARCHAR2(4000) This is return status, should be passed as null.
Functional Rules
The following rules outline the API's behavior depending on parameter usage in the API call:
- If PI_WA_TABLES_COLL is used, it will apply the label only to the entered table(s) and/or view(s).
- If PI_WA_TABLES_COLL is null, the label is applied to all table(s)/view(s) in the Work Area.
- Multiple labels cannot be applied to the same table/view in one API call.
- If PI_DATE is used, the label is applied to the latest Table data load, less than equals to the used date.
- If PI_DATE is not used, the label is applied to latest Table data load.
- If PI_FORCEFLAG is set to $YESNO$YES, the API overwrites the Snapshot Label if already applied, otherwise the label is not applied.
- If PI_FORCEFLAG is set to $YESNO$YES, non-blinded Tables are always included to be labeled.
- If PI_SRC_TAB_COLL is null, and PI_WA_TABLES_COLL has view information or is null (if view exists), the view is loaded and labeled with latest loaded data from the source table.
- If PI_SRC_TAB_COLL has a partial set of source table or views, and PI_WA_TABLES_COLL has view information, the view is loaded and labeled with the latest loaded data from the source table that has non-passed source information.
- If PI_SRC_TAB_COLL is used, the view details should be part of PI_WA_TABLES_COLL.
- If PI_SRC_TAB_COLL is null label will be applied to all table(s) in given Work Area.
- If collection PI_SRC_TAB_COLL is passed with source table's label then view will be loaded and labeled with that data of source table.
- If PI_SRC_TAB_COLL is used with the source table's label as null, then the view is loaded and labeled with latest loaded data of source table.
Parent topic: Define and Modify Work Areas
