Update a Work Area's Usage Intent
Use this API to modify the value of the Usage Intent attribute of a Work Area.
Name
CDR_PUB_DF_WORKAREA.UpdateUsageIntent
Signature
PROCEDURE UPDATEUSAGEINTENT( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PIO_WORKAREAOBJTYPE IN OUT CDR_WORKAREA_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area whose Usage Intent
attribute you want to modify.
The following attributes are required: COMPANY_ID,OBJ_ID,OBJ_VER.
- PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type
CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. For
USAGE_INTENT_RC, enter the new value for the Usage Intent attribute.
The allowed values are: $SYSVALDNSTEPS$DEVELOPMENT, $SYSVALDNSTEPS$PRODUCTION, $SYSVALDNSTEPS$QUALITYCONTROL.
Parent topic: Define and Modify Work Areas
