Create a Work Area
Use this API to create a new Work Area.
Name
CDR_PUB_DF_WORKAREA.CreateWorkArea
Signature
PROCEDURE CREATEWORKAREA( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SOURCECDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE, PIO_WORKAREAOBJTYPE IN OUT CDR_WORKAREA_OBJ_TYPE, PI_DEFCLASSIFICATIONCOLL IN CDR_CLASSIFICATIONS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_WORKAREAOBJTYPE (Mandatory) This is a parameter of table type
CDR_WORKAREA_OBJ_TYPE that contains object attributes specific to Work Areas. Enter values
for the Work Area that you want to create.
The following attributes are required: COMPANY_ID, OBJ_ID, OBJ_VER. For OBJECT_TYPE_RC enter $OBJTYPES$WORKAREA. By default, new Work Areas receive a Usage Intent value of Development.
- PIO_SOURCECDRNAMING (Mandatory) This is a parameter of table type
CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Work Area that you want to
create.
The following attributes are required: COMPANY_ID,NAMESPACE_OBJ_ID,NAMESPACE_OBJ_VER,OBJECT_TYPE_RC. FOR OBJECT_TYPE_RC ENTER $OBJTYPES$WORKAREA.
- PI_DEFCLASSIFICATIONCOLL (Optional) By default the new Work Area is
classified according to the subtype you assigned it in the CDR_NAMING_VERSION_OBJ_TYPE.
If you want to override the default classifications for one or more classification levels, use this parameter. This is a collection of CDR_CLA_OBJ_TYPEs, which have 5 attributes, including CLA_LEVEL_ID and CLASSIFICATION_ID. If you want the Work Area to inherit its classifications for a particular level from its parent Application Area, enter the classification level ID and, for the CLASSIFICATION_ID, enter 0 (zero). If you want to explicitly assign one or more terms for a particular level, initialize a CDR_CLA_OBJ_TYPE for each term, entering the classification level ID and, for the CLASSIFICATION_ID, the term ID. The PAR_ attributes are not relevant to Work Areas. Do not enter any values for them.
Parent topic: Define and Modify Work Areas
