Create an Adapter Domain
Use this API to create an Adapter Domain.
Name
CDR_PUB_ATK_ADAPTER.CreateAdapterDomain
Signature
PROCEDURE CREATEADAPTERDOMAIN( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_ADAPTERDOMAINNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ADAPTERDOMAINNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values for the Adapter Domain that you are creating. For OBJECT_TYPE_RC enter $OBJTYPES$ADAPTERDOMAIN.
The following attributes are required: COMPANY_ID,NAME
Parent topic: Define and Modify Adapters
