Modify an Adapter Domain
Use this API to modify an Adapter Domain.
Name
CDR_PUB_ATK_ADAPTER.ModifyAdapterDomain
Signature
PROCEDURE MODIFYADAPTERDOMAIN( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PIO_ADAPTERDOMAINNAMING IN OUT NOCOPY CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PARAM P_API_VERSION (Mandatory). Enter the current version of the API you are calling. The API compares the version numbers of incoming calls to its current version number and returns an error if they are incompatible.
- PARAM P_INIT_MSG_LIST (Optional). Accept the default value (FND_API.G_FALSE) to ensure that this individual API does not initialize the message list upon completion. Pass FND_API.G_TRUE to override the default behavior.
- PARAM P_COMMIT (Optional). Accept the default value (FND_API.G_FALSE) to ensure that this individual API does not get committed upon completion. Pass FND_API.G_TRUE to override the default behavior.
- PARAM P_VALIDATION_LEVEL (Optional). Accept the default value to perform full validation. No other values are currently supported.
- PARAM X_RETURN_STATUS. This output parameter returns the end status of the API: (S) Success, (E) Error or (U) Unexpected Error.
- PARAM X_MSG_COUNT. This output parameter returns the count of error messages if the return status is other than Success.
- PARAM X_MSG_DATA. This output parameter returns the text of the error message, if the message count is 1. If there are more than one message, use cdr_pub_msg_pub.get to retrieve the messages.
- PARAM PIO_ADAPTERDOMAINNAMING (Mandatory). This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Adapter Domain and enter new values for the attributes you want to modify. All attributes are required. For OBJECT_TYPE_RC enter $OBJTYPES$ADAPTERDOMAIN.
Parent topic: Define and Modify Adapters
