Create and Modify Mappings
- Map a Column
- Map a Table Descriptor to a Table Instance
- Get a Table Instance ID
- Create a Table Descriptor from a Table Instance
- Create a Table Instance from a Table Descriptor
- Modify a Mapping Column
- Modify a Mapping at the Table Descriptor Level
- Get a PRREF_ID for an Executable in a Workflow
- Get a PRREF_ID for an Object in a Work Area
- Get a PRREF_ID for a Program in a Report Set
Parent topic: Mappings
