Modify a Mapping Column
Use this API to update a mapping at the Column level. You can map currently unmapped Columns, map Table Descriptor Columns to different Columns in the Table instance, change the default value for any Column, and supply or change a format string for a Column. This API enforces all Column mapping rules.
Name
CDR_PUB_DF_MAPPING.UpdateMappingColumns
Signature
PROCEDURE UPDATEMAPPINGCOLUMNS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_MAPPING_COLUMNS IN CDR_MAPPING_COLUMNS_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PI_MAPPING_COLUMNS (Mandatory) This is a collection of CDR_MAPPING_COLUMNS_TYPEs. For each Column that you want to modify, initialize a CDR_MAPPING_COLUMNS_TYPE and then extend the collection. All the attributes are required.
Parent topic: Create and Modify Mappings
