Get an Output's CLOB
Use this API to retrieve the CLOB associated with a specified output object.
Name
CDR_PUB_PRINT_OUTPUT.GetOutputCLOB
Signature
FUNCTION GETOUTPUTCLOB( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_NCOMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NOUTPUTID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_NOUTPUTOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN CLOB;
Return
Type CLOB
Description Clob
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_NCOMPANYID (Mandatory) Enter your company ID.
To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.Current_Company_ID.
- PI_NOUTPUTID (Mandatory) Enter the obj_ID of the output whose CLOB you want to retrieve.
- PI_NOUTPUTOBJVER (Mandatory) Enter the obj_ver of the output whose CLOB you want to retrieve.
Parent topic: Generate Outputs
