Get an Output's BLOB
Use this API to retrieve the BLOB associated with an output object.
Name
CDR_PUB_PRINT_OUTPUT.GetOutPutBlob
Signature
FUNCTION GETOUTPUTBLOB( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, PI_NCOMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NOUTPUTID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_NOUTPUTOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE ) RETURN BLOB;
Return
Type BLOB
Description BLOB
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_NCOMPANYID (Mandatory) Enter your company ID.
To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.Current_Company_ID.
- PI_NOUTPUTID (Mandatory) Enter the obj_ID of the output whose BLOB you want to retrieve.
- PI_NOUTPUTOBJVER (Mandatory) Enter the obj_ver of the output whose BLOB you want to retrieve.
Parent topic: Generate Outputs
