Submit a Print Request
Use this API to print a specified output. The API submits a request to the Oracle LSH printing concurrent program that prints the specified output.
Name
CDR_PUB_PRINT_OUTPUT.SubmitPrintRequest
Signature
FUNCTION SUBMITPRINTREQUEST( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_NCOMPANYID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_NOUTPUTID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_NOUTPUTOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE, PI_VPRINTERNAME IN FND_PRINTER.PRINTER_NAME%TYPE := NULL, PI_VCOVERSHEET IN VARCHAR2 := NULL ) RETURN NUMBER;
Return
Type NUMBER
Description Concurrent Request Id
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_NCOMPANYID (Mandatory) Enter your company ID.
To get your company ID, use CDR_DF_PUB_DEF_CONSTANTS.Current_Company_ID.
- PI_NOUTPUTID (Mandatory) Enter the obj_id of the output you want to print.
- PI_NOUTPUTOBJVER (Mandatory) Enter the obj_ver of the output you want to print.
- PI_VPRINTERNAME (Mandatory) Enter the printer name.
- PI_VCOVERSHEET (Mandatory) Enter the text for the coversheet. You can enter text only up to 4000 bytes.
Parent topic: Generate Outputs
