Modify a Parameter Set Definition
Use this API to modify the name or description of a Parameter Set definition.
Name
CDR_PUB_DF_PARAMETER_SET.ModifyParameterSetDefinition
Signature
PROCEDURE MODIFYPARAMETERSETDEFINITION( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_CDRNAMING (Mandatory) This is a parameter of table type CDR_NAMING_VERSION_OBJ_TYPE. Enter values to identify the Parameter Set and enter new values for the attributes you want to modify. You can change the name or description.
Use separate APIs for modifying the validation status and the version label: CDR_PUB_VL_VALIDATION. UPDATEVALSTATUS and CDR_PUB_DF_NAMING. UPDATEVERSIONLABEL. All attributes are required.Parent topic: Create and Modify Parameter Sets
