Modify a Parameter Set Detail
Use this API to modify Parameter Set details.
Name
CDR_PUB_DF_PARAMETER_SET.ModifyParameterSetDetails
Signature
PROCEDURE MODIFYPARAMETERSETDETAILS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_CDRNAMING IN OUT CDR_NAMING_VERSION_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_CDRNAMING Naming details of the parameter set object to be modified.
Parent topic: Create and Modify Parameter Sets
