Modify a Subtype
Use this API to update a subtype.
Name
CDR_PUB_SECURITY_PKG.ModifySubtype
Signature
PROCEDURE MODIFYSUBTYPE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_SUBTYPE IN OUT CDR_SUBTYPE_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_SUBTYPE (Mandatory) This is a parameter of table type CDR_SUBTYPE_OBJ_TYPE that contains information about the object subtype.
Parent topic: Create and Modify Security Policies
