Create and Modify Security Policies
- Create a Subtype
- Copy a Subtype
- Modify a Subtype
- Assign Roles to a Subtype Operation
- Assign Operations to a Subtype Role
- Remove a Subtype
- Create a Role
- Modify a Role
- Add a Group Role
- Get Roles for a User
- Remove a Role
- Remove a Group Role
- Create a User Group
- Add Users to a Group
- Remove Users from a Role in a User Group
- Assign a User Group to an Object
- Copy a User Group
- Copy a User Group with its Users
- Modify a User Group
- Remove All Group Roles from a User Group
- Remove All Users in a Group
- Revoke a User Group From an Object
- Undo a Revoke a User Group Action
- Remove a User Group
- Unassign a User Group From an Object
- Unassign Roles from an Operation on an Object's Subtype
- Unassign Operations on an Object Subtype's Role
- Initialize Access to a Security View
- Prevent Access to a Security View
- Get the Resource Timeout Limit
- Set the Resource Timeout Limit
- Reset the Resource Timeout Limit
Parent topic: Security Policy
