Modify a Role
Use this API to update a Role. You can change the name, description, and Active status of a Role.
Name
CDR_PUB_SECURITY_PKG.ModifyRole
Signature
PROCEDURE MODIFYROLE( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_ROLE IN OUT CDR_ROLE_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ROLE (Mandatory) This is a parameter of table type CDR_ROLE_OBJ_TYPE that contains attributes related to a Role.
Required Attributes are: NAME,CODE,OBJECT VERSION NUMBER (pass 1 for this).
Parent topic: Create and Modify Security Policies
