Add a Group Role
Use this API to create roles for a User Group.
Name
CDR_PUB_SECURITY_PKG.AddGrpRoles
Signature
PROCEDURE ADDGRPROLES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_ROLES IN OUT CDR_UG_ROLE_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ROLES (Mandatory) This is a parameter of table type CDR_UG_ROLE_OBJ_TYPE.
Following attributes are required: COMPANY_ID,USER_GROUP_ID,ROLE_ID,OBJECT_VERSION_NUMBER
Parent topic: Create and Modify Security Policies
