Remove a Group Role
Use this API to remove a single Role from a User Group. You can remove all Roles from the User Group at the same time by using the Remove All Group Roles API.
Name
CDR_PUB_SECURITY_PKG.RemoveGrpRoles
Signature
PROCEDURE REMOVEGRPROLES( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PIO_ROLES IN CDR_UG_ROLE_OBJ_TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_ROLES (Mandatory) This parameter is of table type CDR_UG_ROLE_OBJ_TYPE that contains information about User Groups and Roles.
Parent topic: Create and Modify Security Policies
