Promote a Clinical Data Model to Quality Control or Production
Use this API to promote a study clinical data model to either the Quality Control or Production validation status.
Name
DME_PUB_DF_DATA_MODEL.UpdateValStatus
Signature
PROCEDURE updateValStatus( p_api_version IN NUMBER p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL pio_naming in out nocopy cdr_naming_version_obj_type x_return_status OUT NOCOPY VARCHAR2 x_msg_count out nocopy number x_msg_data OUT NOCOPY VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- P_VALIDATION_LEVEL
- PIO_NAMING (Mandatory): This is a parameter of type
CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model that
you are promoting.
PIO_NAMING.VALIDATION_STATUS_RC (Mandatory): Enter the validation status to which you are promoting the clinical data model:
'$SYSVALDNSTEPS$DEVELOPMENT'
'$SYSVALDNSTEPS$QUALITYCONTROL'
'$SYSVALDNSTEPS$PRODUCTION'
Parent topic: Create and Modify Clinical Data Models
