Remove a Clinical Data Model
Use this API to delete a study clinical data model.
Name
DME_PUB_DF_DATA_MODEL.RemoveStudyDataModel
Signature
Procedure RemoveStudyDataModel( p_api_version IN NUMBER p_init_msg_list IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_commit IN VARCHAR2 default CDR_PUB_DEF_CONSTANTS.G_FALSE p_validation_level IN NUMBER default CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL pio_StdyModObj IN OUT NOCOPY cdr_naming_version_obj_type x_return_status OUT NOCOPY VARCHAR2 x_msg_count OUT NOCOPY NUMBER x_msg_data OUT NOCOPY VARCHAR2);
Parameters
This API has standard parameters (see Standard Parameters) and the following parameter:
PIO_STDYMODOBJ (Mandatory): This is a parameter of type CDR_NAMING_VERSION_OBJ_TYPE. Enter attributes for the clinical data model that you are removing.
Parent topic: Create and Modify Clinical Data Models
