Remove Validation Check(s)
Use this API to remove validation check(s).
Name
DME_PUB_VALIDATION_CHECK.RemoveValidationChecks
Signature
PROCEDURE REMOVEVALIDATIONCHECKS (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PIO_VC_COLL IN OUT NOCOPY CDR_NAMING_LIST_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PIO_VC_COLL (Mandatory). This is a parameter of collection type
CDR_NAMING_LIST_COLL that contains CDR Naming Version attributes.
The attributes required for this API are:
- COMPANY_ID
- OBJ_ID
- OBJ_VER
Parent topic: Create and Modify Validation Checks and Batches
