Upgrade a Validation Check Batch
Use this API to upgrade a validation check batch.
Name
DME_PUB_VALIDATION_CHECK.UpgradeValidationCheckBatch
Signature
PROCEDURE UPGRADEVALIDATIONCHECKBATCH (P_API_VERSION IN VARCHAR2, P_INIT_MSG_LIST IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 DEFAULT CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER DEFAULT CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT NOCOPY VARCHAR2, X_MSG_COUNT OUT NOCOPY NUMBER, X_MSG_DATA OUT NOCOPY VARCHAR2, PI_BATCHMAPCOMPID IN CDR_NAMINGS.COMPANY_ID%TYPE, PI_BATCHMAPOBJID IN CDR_NAMINGS.OBJ_ID%TYPE, PI_BATCHMAPOBJVER IN CDR_NAMING_VERSIONS.OBJ_VER%TYPE );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_BATCHMAPCOMPID (Mandatory). Enter COMPANY_ID of Validation Checks Batch Map.
- PI_BATCHMAPOBJID (Mandatory). Enter OBJ_ID of Validation Checks Batch Map.
- PI_BATCHMAPOBJVER (Mandatory). Enter OBJ_VER of Validation Checks Batch Map.
Parent topic: Create and Modify Validation Checks and Batches
