Upgrade All Execution Setups
Use this API to upgrade all the Execution Setups associated with an object.
Name
CDR_PUB_DF_EXECUTIONSETUP.UpgradeExecSetups
Signature
PROCEDURE UPGRADEEXECSETUPS( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_EOICOMPID IN NUMBER, PI_EOIOBJID IN NUMBER, PI_EOIOBJVER IN NUMBER, PO_NOTRUNNABLEESLIST OUT CDR_BASE_OBJ_COLL );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_EOICOMPID (Mandatory) Enter the COMPANY_ID of the executable object instance for which the Execution Setup is intended.
- PI_EOIOBJID (Mandatory) Enter the OBJ_ID of the executable object instance for which the Execution Setup is intended.
- PI_EOIOBJVER (Mandatory) Enter the OBJ_VER of the executable object instance for which the Execution Setup is intended.
- PO_NOTRUNNABLEESLIST This is an output parameter that returns a collection of CDR_BASE_OBJ_TYPE containing Execution Setups whose status has changed from Runnable to Not-Runnable.
Parent topic: Create and Modify Execution Setups
