Upgrade an Execution Setup
Use this API to upgrade one single Execution Setup.
Name
CDR_PUB_DF_EXECUTIONSETUP.UpgradeExecSetup
Signature
PROCEDURE UPGRADEEXECSETUP( P_API_VERSION IN NUMBER, P_INIT_MSG_LIST IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_COMMIT IN VARCHAR2 := CDR_PUB_DEF_CONSTANTS.G_FALSE, P_VALIDATION_LEVEL IN NUMBER := CDR_PUB_DEF_CONSTANTS.G_VALID_LEVEL_FULL, X_RETURN_STATUS OUT VARCHAR2, X_MSG_COUNT OUT NUMBER, X_MSG_DATA OUT VARCHAR2, PI_ESCOMPID IN NUMBER, PI_ESOBJID IN NUMBER, PI_ESOBJVER IN NUMBER, PO_UPGRADESTATUS IN OUT VARCHAR2 );
Parameters
This API has standard parameters (see Standard Parameters) and the following parameters:
- PI_ESCOMPID (Mandatory) Enter the COMPANY_ID of the Execution Setup.
- PI_ESOBJID (Mandatory) Enter the OBJ_ID of the Execution Setup.
- PI_ESOBJVER (Mandatory) Enter the OBJ_VER of the Execution Setup.
- PO_UPGRADESTATUS This is an output parameter that indicates whether or not the Execution Setup's upgrade was successful.
Parent topic: Create and Modify Execution Setups
