Change the state of multiple discrepancies
  1. After you select a study, click Data Management. Data Management in the navigation bar.
    For details on selecting a study, see Select a study from the Home page.
  2. Select Discrepancies from the drop-down menu.
  3. Find the discrepancies you need to locate using the filters on the left panel or the top of the page. (See Find discrepancies for details on using the filters.)
  4. Select one or more discrepancies. To select adjacent rows, press Shift as you click rows (or press the down arrow key). To select nonadjacent rows, press Ctrl as you click rows.
    Tip:
    You can skip the remaining steps and use keyboard shortcuts to select Ready to Send to InForm by pressing Ctrl+Alt+Q. Or, close one or more discrepancies by pressing Ctrl+Alt+C. Use the down arrow keys to open the drop-down list and select an option. Press Tab to navigate to fields and enter a comment (if necessary). Press Tab to navigate to Submit and press Enter.
  5. From the Manage Discrepancies drop-down, select the action to take (for example, Close Discrepancy or Ready to Send to InForm). The drop-down list only includes valid actions for the discrepancies you selected. A new dialog box with the name of the action you selected opens in the right panel.
  6. In the Reason field, select a reason from the drop-down list. Or, enter reason in the Comment field instead. (If you select a reason and enter a comment, Oracle DMW only saves the reason.
  7. Click Submit.
